RACER-X
- 1,037
- 1
- May 26, 2002
Corpus Christi,
Texas
hey guys i have a problem, well actually two.
the 1st one deals with either the tranny (man, i hope not), clutch, shifter cables, or maybe the master cylinder.
it's a little difficult to get my car in gear ( i have a act 2600 with street disk), but after about 10 to 15 min of driving it dosen't want to go into gear and i sometimes i have to force it into gear. it's fine the first few min of driving but progressively (s/p) gets worse. tranny fluid has been changed and old fluid was a little dark but clean and was not low. the peddle has a little bit of play at the top and when it becomes hard to shift i have to push it to the floor board and sometimes i feel a pop. stick also has a little bit of play. has anyone had a similar problem?... what could this be?
my second problem is that i installed my 225 fuel pump and i did the rewire. now at idle or if i turn on the a/c my gas light will come on, where you can barely see it and fade in and out until i turn off the a/c or until i take off. did i wire something wrong?
