NEO
- 30
- Oct 24, 2002
i just want to know the differece between the two cause i wanna get one in and i just want to know which one will fit my needs to get the most out of my engine......free up dem horsies!
Originally posted by talonted_one
Drop Ben k a line he is awesome with this.
Originally posted by swordfish
First of all, what are your goals? That will make it easier for us to provide you with information.
The 50 trim compressor, for those compressor map junkies out there, is rated at 49lbs/min while the 60 trim is rated at only 50lbs/min. But, the 60 trim is an off the shelf garrett unti so it is a bit less than the 50 trim setup, provided you are wanting the stage 3 turbine wheel. I've seen cars with either compressor run in the 10's.
jeff
