truwarrior
- 1,422
- 6
- Dec 19, 2002
Just wondering if cuting the dump tube will affect my bov from holding boost. I was thinking since the dump tube is so deep into the snorkle what maybe the turbo sucking in air would create a vacum in the dumptune and help keep the bov close. Not sure on the design of the 2G bov though... What do u think? With my current mods I don't wanna cut it and loose and psi.
What are you smoking? having the god ugly pipe stuck down your intake is in no way good. and even if it had a slight VAC on it it be pullin the BOV open not shut!!! that little vac hardly matters but what little extra vac you might elimante it will be an advantage
