Clipse
- 509
- Sep 25, 2002
Renton,
Washington
I am just curious if there are any 2g guys out there using the Hallman Pro MBC? If so, I just want to double check to make sure I am doing the install correctly. So, moving forward. I disconnect the line coming from the compressor housing to the "T" that connects to the wastegate, and to the boost control solenoid. Cap off the boost control solenoid and keep it plugged into the wiring harness. Then run the new lines from the bottom (or wastegate) part of the MBC to the Wastegate actuator nipple, and the top (boost source) part of the MBC to the compressor housing. Then mount the b!tch and play hard....right? Am I missing anything??
Danny
Danny
