Blizz92tsi
- 269
- Jul 12, 2002
Joplin,
Missouri
Hey guys,
This may not be extreme enough for this forum. If its not I appologize and please move it to the appropriate forum.
I'm now on my second dsm. My first was a 1992 awd talon. That one was stolen shortly after I put a lot of money into mods. Six months later I came across a 1990 talon awd for the right price. It has a few mods but I'm going to redo everything. This time around I'm wanting to go as fast as I can go on a 14b. My car has some sort of 16g on it right now and I was wanting to buy a used 14b that needs a rebuild. If one were to rebuild a 14b what mods would you have done to make the 14b the best it can be? Porting both turbine and compressor housings, and wastegate flapper mod would be done. Would any of you change the wheel sizes for better flow or efficiency? What are the big differences between the 16g and 14b? Do the really fast stock turbo guys do anything special to their 14bs? Thanks for your help. Again my appologies if this isn't quite extreme enough. But I figure running really fast quarters on the stock turbo is going to require some extreme measures.
I may make a key chain out of it or something... I used to run slightly faster on a "good" 14b with half the mods I had that night, so I think the rebuild will help. Otherwise all you have is porting, and like Kyle said, I never gained anything by porting everything on my 14b setup. I ran 12.7s ported and unported. But you should do it none the less. And for more info on the larger flapper thing, see a thread I started here that goes something like "internal wastegate blowing open info" or something to that effect. Here it is,
Thread moved.
And the pull kept going and going and going to the red spot
nly problem noe is that I heat soak my intercoolerand get knock on hot days..My friend has a GSX with a BIG 16G and my 3rd gear pull is just as hard, but he has a harder pull as his rpms get higher. and he also has a strong top end.
