Eniygma
- 55
- Jul 19, 2002
Bowie,
Maryland
Has anyone experimented with getting a cold air intake on a '90 "pop-up" headlight Eclipse?
I have done this....I took out my headlights, just as an experiment and cut a larger hole to the air filter (w 2G MAS/K&N Filter) and unplugged the left side pop-up motor just so that I could pop the one side for a movable "Scoop". I drove to work this morning...Here are the stats in my area:
66 Degrees F
Dew Point: 57°F
Humidity: 73%
Pressure: 29.89 inches and rising
The Air Temp reading to the MAS was between 75 and 101.
To make a long story short....I would pop the "scoop" at highway speeds and at stand still.....The only time I noticed a temp drop from roughly 78-84 was when I was standing still in traffic...I would pop the headlight and temps would drop about three degrees, Sometimes!!
But when traveling 75 on the highway, my temp stayed at about 74, with the "scoop" up or down..no change at all. Test results were WAY inconsistent.
Can anyone tell me why this would be and has anyone got a better idea for cold air? How about a screen vent over the Air Intake....how do you keep water out?
Any suggestions would be great!!
66 Degrees F
Dew Point: 57°F
Humidity: 73%
I think I have the perfect plan....for cold air. I am goinmg to do this this weekend if weather permits and I'll tell you you how it comes out. I am going to cut some very precise holes in the hood and screen them, two just above the intakle and one long one in front of the turbo. I will use a magnetic sheet to cover the one above the intake when it rains, however, I am going to install a rian gutter lip on the underside, just to be safe. I will post picks soon....
