AFC with a Dual MBC
16GTSI
148
May 9, 2003
Metamora, Michigan
I am looking to run a turbo xs dual boost controller. I am also looking at running 550's with an AFC. My question is....If i was to set one mbc setting for 8psi and the other for 16-18 psi, would the same settings on the AFC work for both boost settings??
No. You are flowig WAY more air at the higher setting than the lower.
you would need an s-afc2. it has high and low boost settings. that you can switch between
wonder if that will work the same with the profec b spec 2? although i see little need for a less than max boost setting, LOL
