s-afc question
Eagle 5
380
3
Jan 26, 2003
Cincinnati, Ohio
is the S-afc enough for running a 20g, fp green, or fp3055? or would i need a stand alone? i m sure the stand alone would be better but is the s-afc enough? supporting mods will be there just wondering if the s-afc is enough or if it can handle it
It's not so much the SAFC that can or can not handle it but the size of injectors. You can use the SAFC and 550's for that setup but you would be better off with 660cc's with that and the SAFC. As long as you set your car up properly and tune it properly it will be just fine. Make sure you have a Walbro 255HP in your car too.
Enough to make the car run? Sure. Enough to make it run worth a damn? Not in my opinion. The fact that an AFC is available, and it's so cheap is the exact reason why people with any of the above turbos are still stuck in the 12's. To anyone that is running 12's with one of those turbos, you must be pretty embarrassed. You can run 12's on a 14B. Heck, you can run 11's on a 14B. I'd sure turn several shades of green if my FP Red car just got schooled by Leon's 14B car... Just food for thought.
Regards,
