Smokin GST
- 50
- Dec 24, 2002
my car will be done this weekend... crankwalk recovery.
here will be my setup (this is in a 97 GS-T):
2G MAS (duh)
MKIV supra intercooler
1G BOV (slightly crushed, no compressor surge!)
2G throttle body elbow
1G throttle body
1G intake manifold
1G head
6-bolt bottom end
2G exhaust manifold
14b turbo
2G O2 housing
stock 2G FWD Turbo exhaust (will be doing 2.5" cutout soon)
i am using the RRE j-pipe for the 14b install. none of the parts are ported. i ran 16psi on the T-25 just fine, no fuel cut problems or knock problems. but now i'm going to have a 14b (yay for JDM motors). i'm curious what the highest efficient boost level is on a 14b, and what is the highest SAFEST level to run. now realize that i don't constantly beat on my car... i drive like an old woman 90% of the time, but when i ring it out, i stand on the gas pedal for a while.
i was thinking 18psi, but i don't know if that will be too hot (16psi was probably too much from the T-25). i plan to start at 15psi and work my way up, checking for knock along the way, and finding a boost level where i don't hit fuel cut. i'm just curious if anybody has a similar setup, and what kind of boost levels you are running. my fuel system is completely stock. need to get off my butt and rewire the fuel pump.
here will be my setup (this is in a 97 GS-T):2G MAS (duh)
1G throttle body
1G intake manifold
1G head
6-bolt bottom end
2G exhaust manifold
14b turbo
2G O2 housing
, i like the way you put that.. yea, i don't want to see my new 6-bolt turn into a smoldering block of glowing red goo...
