lil4x4dsm
- Nov 7, 2002
this is the first thread i have started, i can normally find awnsers searching th board, no luck so here it goes....i ordered the mitsubishi specialties stage 3 eprom( the one jdmawd was referring to on ebay), with the eprom comes the clutch-cut wire for the stutter-box option. insalling the zif sochet and eprom was a breeze, went so well we replaced the capaciters as well!!! put ecu back in the car and ran the clutch-cut wire to the switch. when i first hooked it up to the switch i used the lower switch, the one that shuts off cruise control if you push the clutch in. well the stutter-box worked awesome when the clutch was out!!! ooopps. i found the correct switch up top and hooked it up the same way( spliced into green wire) and i get nothing.....no stutter. i rechecked all solder points and everything is good. to make sure the wire wasnt screwed up i rehooked it up to the lower switch and it works perfect. what the hell am i missing??????? it looks like the same switch top and bottom, why does one work and one not?? i even went as far as hooking it up to the black wire just in case wires where in wrong location??? im lost, please throw any ideas you can think of my way
greg
greg
