Z0rr0
- Dec 21, 2002
Clarkston,
Washington
i blew my engine, so i figure wihile its out, why not spend an assload of cash, and build it right.. here goes
Already have:
TD05 16G (Standard, not Big)
Hard Lower Intercooler pipe
1G BOV w/ Custom Aluminum Flange
Translab Shift Kit (not installed, engine belw after turbo install)
Looking to do:
Head:
Nitrate Coated Valves
Bornze Valve Guides
Crower Titanium Retainers & Crower Springs
Stock Cams (for now)
Cometic Metal Headgasket
ARP Head Studs
Bottom end:
Weisco Pistons and Rings (9:1 or 8.5:1??? i have 95 oct. available here at a reasonable price)
Eagle Rods
B/S Elim.
Celvite 77 Rod and Main Bearings
ARP Rod Bolts (come with the pistons)
Mitsu OEM Crank Fasteners
Of Course new gaskets all the way around
i also plan to port the exhaust mani to 7CM
within 2 months, i should have 550cc injectors, AFC, and 255lph pump, as my fuel system is stock right now
ive been thinking of a stage III chip as well, but will the auto take advantege of the higher 8500 RPM redline?
im looking at about $2500 for this setup including a new oil pump..
should i replace the oil pump if it looks good? the car has 138,000 on it.
thanks
-Z0rr0
95 Talon TSi AWD A/T
Already have:
Looking to do:
Head:
Bornze Valve Guides
ARP Head Studs
Bottom end:
Eagle Rods
B/S Elim.
thanks
-Z0rr0
