Newlogics
- 1,106
- 18
- Jul 23, 2002
San Leandro,
California
Hey guys.
My question is regarding grounding. Which rules apply ?
Does grounding work by 'the more - the merrier' rule ?
I've replaced my stock grounding wires with bigger ones, and also added several more grounds.
I don't know if what happened was a coincidence, or was caused by extensive grounding, but here's the story:
Right after I installed those ground wires, we went to the track and after the first pass my temp and EGT gauges started to wabble and act weird. EGT pointer was pointing directly downward (off the scale), and my stock temp gauge wabbled for a while and then went to hot and stayed there (with minor fluctuations) through the whole trip back.
Right before that pass, my car wouldn't start so we had to push-start it. After the pass, we had to push start it again (all power devices like seatbelts and windows were working perfectly, not showing signs of low battery) car would click, but not start. ON the way home, logger was showing 12v on the battery at first, then slowly got to 9 volts by the time I took my exit, that's when fuel pump relay switched of and car died. Note that my aftermarket temp gauge and logger didn't show and excessive overheating, so stock temp gauge was obviously acting like that due to lack of voltage.
After I dropped new battery in the car, everything went back to normal, and voltage is at 13v, which means its chargin and alternator works fine.
So was this whole thing caused simply by dying battery, or did new grounding play any role in it ?
