Solutions for regulating boost in 1st gear?
how do you want to regulate it? if your getting too much boost in 1st gear I wish I had the same problem. I have the avc-r it would allow you to tune your boost acording to gears. I usualy ony get around 7-8 lbs of boost in 1st, with a hrc s20g. post a little more on how you want to regulate it and mabey some one will be able to help you out more.
Dejontool.com has a dual stage boost controller. They used to have a triple boost controller, but it's not on the site anymore. Maybe if you ask they might build one for you.
