THEDUKE
- 91
- Jan 23, 2003
Bristol,
Tennessee
If I take the FMIC from the conquest & have the pipes changed to 2 1/2 inlet & outlet will it be worth my time . I went to the track & am getting good 60 foot times (for a slipping clutch & 2nd that want shift) but not pulling good top end, the clutch was holding in the upper gears except on the shift. Time was 12.96 - 60 1.72 - MPH 104.99. I had to turn the bottle off to get this because of the clutch . The boost was at 20 - I know to much for the stock cooler. With the nitrous I pull it back to 17 & I also run 114 or 110 fuel in the car all the time, but will the conquest cooler be worth modifying & running. Money is short at this time and the drag strip is running. I have the FMIC from the conquest already & plan to spend on the ACT 2600 street clutch before I do a good front mount. Maybe if I had left the boost at 17 it would have pulled better but some sort of front mount should help this alot. Im running the big16 & would like to get the most out of it I can. After the FMIC a set of forged slugs & a 20g or hibrid will be on the list but untill then Im going to have to push this 16.
THANX
THANX
The last one went on his boss's blown Hummer H2. Wicked car. ran a 13.82 at the track, impressive for how heavy it is.
. I would not be surprised that someone has gone slightly faster by now (4-5 years later).
