How much Boost is too much?
100shotofNOS
32
Jun 10, 2002
Alabama
I just bought some parts for my ca and I dont know how much PSI I should run.
The parts are:
Walbro fuel pump
TurboXS dual stage boost controller
Apexi SAFC II
HKS Turbo Timer
550cc injectors
3" turbo back exhaust
HKS bov
I want to run about 20 PSI. Will it be safe to do it with these mods? If not what else should I do.
The parts are:
Walbro fuel pump
Apexi SAFC II
HKS Turbo Timer
550cc injectors
HKS bov
Not on the 14b and pump gas. It's too small and constipated for pump gas at that boost level. Race fuel, go for it all day. (Race Fuel ='s C16 to me)
Originally posted by Antilles
Thats a bold statement. I have more mods than him and I cant touch that kind of boost on pump gas. 18-20 is most certainly NOT "safe"
What compression ratio are you running???if you have a built motor with 9:1 compression pistons and he has a stock motor with 7.8:1 pistons, then I’d say that’s the reason he would be able to run 18-20psi
Yes, and no. Yes I have 9:1 pistons, and have to run lower boost because of it, and no, that doesnt make it safe to run 18-20psi on stock lower compression pistons. My friend has almost that EXACT same setup. AFC, 550s, stock IC, big 16G. He can only run 16 psi. Myself, I can only run 14-15.
ANYTHING over 16 any time is asking for trouble without any kind of logging capability.
i had my 90 gst at 18 psi at the track on 93 octane and i had a run with no fuel cut and ran a 13.3, that was with a filter, exuast, and stock tires, i spun like hell and lost grip in first and second when i hit full boost, but it was ok, i dont know how safe it was but my car was fine after, now i got new 2g pistons, head, 2g manifold, and other lil stuff, i am gonna run about 18-20 at the track
