deyes
- 104
- Apr 15, 2002
Heres a few pics of the impossible to reach O2 housing bolts. Luckily it all came off without a hitch, we used liquid wrech and no bolts broke. These are pics with AHP's 2.5 in O2 housing going on, and a few comparison pics. It should be said of the O2 housing that the turbo side has the same diameter opening as the stocker, however it is much larger on the inside and the downpipe side. This is an undercar close up of the the front of the O2 housing bottom bolt, it required a sort of threading manuver where we put the washer and nut in and tightened the nut down as we moved the O2 sensor into position little by little. If youv'e done a similar O2 sensor housing install you know what I'm talking about.
