2 stage mbc
GSpoT
Feb 9, 2003
Just got my boost gauge in right before I had to leave for work....anyway I noticed I'm reading 15psi and and spikes at 17...now from what I understand the t25 can handle 15psi and after that its pretty much slammin hot air in, right? My questions are, I have a Turboxs 2 stage mbc sittin in my room with those readings what can I set it at, and if (lets say for sh1ts and giggles)I set it at 20psi on the second stage, whats the worst that could happen? Internal engine damage or after time a blown turbo(reason to upgrade sooner:thumb:)By the way I have my boost gauge tapped into the fps and it was 30 degrees out, car was runnin ssweeeeeetttt!!!
if you set any higher than 15 the pressure will start falling down. t-25 can't hold boost after a certain point. and im not totally sure if you can go that much higher than 15/16 lbs on stock pump. if you set at 20 lbs and your car is properly tuned, go for it, but again the presure will start falling down :) just get rid of that t-25 and upgrade to a t-28 :)
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
