Datalogger hook up help
DSMTommy
138
Jan 20, 2003
How exactly do you hook up the wires from a palm to the OBD2 port. I have the Hotsync cable into a doulble male serial and then the OBD2 cable serial in the other side of the double male and then out to the OBD2 connector. Is this correct? If not, how do you people with loggers have your cords????
One end of the OBD2 cable plugs right into the hotsync cable from the palm.
my OBD2 cable has a female end and so does my Hotsync cable so I used a double male to connect them. I'm using Tunerstein and I constantly get "error - no Rev" when I try to hook it up. Don't know if it is the cable or the program???
