Quesion about intercooler?
AWDTURBO02
Mar 8, 2003
on my 90 gst i have a bad intercooler leak and i have a really bad fuel cut problem. the leak is not coming from my plumbing i think i have a hole in my intercooler also i am boosting at 16 pods when i hit 10 it goes n wher and my boost is at full. what do i do get a new intercooler? and should i buy bigger injectors?
:confused:
Fix the leak. Pressure test the system or you could take the intercooler to a radiator shop and have them pressure test it the same way the do radiators. It is possible to epoxy a leaking intercooler or you could buy a used unit cheap or now would be a good time for an upgrade. Your profile says your car is stock so injectors are not needed at this point.
very easy depending on the size of the leak. first i would pull that stock ic off. Then i would clean out the inside with some gas (there is a vfaq about this). Then pressure test the ic to make sure that is you problem. If there is a hole, JB weld does wonders. Make sure the area is prepped good, sanded down and cleaned off. That should do it for you. Let the Jb weld cure for a day.
brian
new eng dsm
Originally posted by ivanr4g63
Agree... It shouldn't be that hard to fix your existing IC...
