tqlla
- 165
- Nov 23, 2002
Hey, I just bought a 92 Turbo intake and throttle body. I am also planning on doing the ARP head studs(in the near future).
Do I have to remove the Head to replace the headstuds. If not should I worry about the Headgasket seal breaking? I am pretty weak when it comes to working with the engine, past the manifold. I read the VFaq, and it had a head that was already out(so I am not sure if that means the head needs to be out)
If I do need to remove the head, then I probably will do the 1G head, when my 60K comes up(I will probably fork over the cash to have someone else do it and the 60K). If I dont need to remove the head, then I will just port match the 2G head.
You still need to take head off for porting
