Home Depot intake mod
Dieselboy
2,359
Nov 6, 2002
Seattle Area, Washington
Home Depot Performance inc. has come with yet another high quality performance part for your DSM enjoyment.......
Okay enough crap. A while ago, someone posted up on what parts they'd need from Home Depot to make a home made intake. I said that I'd be the one to make out a prototype to see if it works. Well, if you read my mods, I did it about a week and a half ago, and it came out quite nice. Its not a completely perfect fit (I used straight pipe for better flow), but it certainly does the job and Ive had no complaints or problems over the past 2 weeks with it. Do not pay $100+ for an intake from Dejon Tool, Mach V, or anywhere else. This project will cost you less than $20.
Ill list the stuff you need below, as well as the steps youll need to take. I will also post pics on here in a day or two. All the parts I list are from Home depot, so for instance, if you have rubber reducers/couplers of your own, the measurement of the pipe may slightly have to be shorter or longer. So this is my vfaq on how to make one....
Parts youll need from Home Depot:
-1 foot of 3" ABS plumbing pipe. Dont worry, its quite thick and does the job (its black, found in the plumbing section where all the pipe is at).
-1 rubber 3" coupler. Black, and has two clamps on it (also found in the plumbling section)
-1 rubber 3"-to-2" coupler. Appears the same as the above coupler.
-1 1" drilling bit (you will need to drill a hole for the dump tube)
-1 tube of sealant or bonding adhesive (I used sylicone sealant, but Id recommend something stronger like JB Weld, caulking, rubber cement, ect...)
-1 roll of black tape. Can be duct, plumbers, electrical tape, ect... This is mainly for a cosmetic purpose, but also does serve in keeping the dump tube inside/in place.
A hack saw or something to cut the pipe
Making the intake pipe
1). Remove your entire stock intake unit. Then seperate the MAS from the stock intake tube.
2). Take a flat head screw driver can carefully pry the metal dump tube out of the stock rubber intake piece (you can use sealant to seal the tube back in there if you ever want to switch back to stock).
3). Cut about a 6" section of the ABS pipe. Try to get the ends as straight and flush as possible. Sand or file smooth if desired.
4). Decide which end will be the MAS side, and which will be the turbo side. On the MAS side, about 1½" from the end, CAREFULLY drill the 1" hole for your dump tube. Then take a file and begin to smooth and slightly enlarge the hole. File the hole JUST big enough to squeeze the end of the metal dump tube into. By no means do you want to make it to large.
5). With the dump tube hole done, take the tube back out, take your sealant/bonding adhesive and carefully line the end of the dump tube with it. Stick it in the hole you just drilled and place another coating over the outside also to seal the tube in place and make it air tight. Allow at least 30 minutes to dry (will vary with what product you use). After it drys, take your black tape and neatly wrap around the whole intake tube, as well as the bottom of the dump tube and the area you sealed. Do a neat job, while also helping to reinforce the tube.
6). Place the couplers on the finished intake tube (3" on the MAS side, 3"-to-2" on the turbo side). You will need to wrap the end of the MAS with tape or something, to make it larger so you can have the extra diameter to place the coupler on it (what I actually did was cut the section of the stock rubber intake pipe that fits there and used that, it works perfect). You will also need to cut a small section in the 3" coupler to make wat for the vacuum hose conection. Just cut a small line/strip out with scissors so that it slips over the vacuum connection.
7). Place the finished intake product back on the car. You will need to use the rubber section that fits on the turbo as well in order to properly fit (you should see the section when you took the stock rubber pipe off). I found I have to put the intake pipe on first, then place the MAS on after its installed. You MAY have to do the same. Tighten all clamps.
The intake will slightly be pointing up due to the fact the pipe is straight, not an "S" pipe. Make sure your filter clears the hood line. If not, go back, loosen up the clamps, and make sure the pipe is as far in as it will go. If its still a problem, you may need to cut another ½"-1" off the pipe. The measurements I gave you should work perfectly though. Your finished product should look simular to stock if left black. You can opt to paint it if youd like to.
REVIEW
Spool and BOV are MUCH louder. Seems to be better throttle response and accelleration. I did a K&N at the same time and made a huge difference over stock. Appears stock to the untrained eye. Definitly worth $20. KEEP IN MIND that this was done on a 14B powered 1G so other applications may vary slightly. Hope it works for you as well as it did for me. Good luck :thumb:
Disclaimer: Im not responsible for something getting fawked up on your car if you somehow mess something up. This mod wont work with a stock air can being used as well ;)
DERIQUE EL RICER SLOWBOY j/k
I saw and heard the results of his intake, excellent for the price. Definitely gonna slap it together on my car.
I've been running my HD intake for about 6 months or so, and has treated me right!!
need some help someone please give me directions to make a home depot intake...also wont my turbo make more noise if all my icp was hard pipe? thanks
No Home Depots here just Lowes. My 7 dollar Dryer Duct, ABS Intake/Air Filter Relocation Mod :) Ghetto Style
Part2
Originally posted by larryd
Maybe its just me but Id much rather spend 100 bucks and have a nice intake from Dejon tool :) to each their own though right..
I figured I do the Cheapo since I'll be changing turbos in the future.
Thats funny I am the one that posted the need for the parts list for the homedepot intake. What I found is like you said that its easier just to use a 6" straight peice of 3inch pvc, a 3" to 3" fernco conector, a 3" to 2" fernco conector and a threaded thingy for the blowoff line. Then all you do is put it all together well after you drill a hole in the straight pvc and thread the thing into it for the blowoff valve. If I took the two 45 degree bends back it would probally cost 10 dollars to build. I noticed a quicker spool, alittle more power, and better spool and blowoff valve noise. This is probally the best mod you can do for the money other then building a mbc. But I probally didnt need this cause my small 16g already spools to fast and I cant stay out of boost so my gas milage is suffering.
Drew
here's my new intake
the filter.
my cost was a little more, about 30 in metal tubing, and a 3" silicone coupler with clamps will be about 10. it will be jet hot coated too, so 12.5/ft also.
I actually made my intake with a couple of ABS elbows and rubber couplers found at Home Depot. It was fine for a while, but I found that the clearance was a little tight and would get frustrating when trying to remove and install the piece every so often. I ended up snapping the nipple on the wastegate actuator last time and tore up the 3x2 coupler trying to get it onto the turbo inlet. I finally shelled out the money for a Dejon pipe and am completely happy with my purchase. Great fit and much better looking. No more headaches.
For those who don't have the money for an intake pipe, this mod is great. But there are some benefits to spending the money.
