Me4g63U
- Apr 5, 2003
I recently installed the Supra Sidemount. I am now seeing boost spikes to 20 psi and fuel cut. Once the spike settles to 15 psi, the car runs fine and maintains boost so I don't believe there are any leaks. I am not able to reduce the spikes with my MBC. This never happened before the intercooler install. Any suggestions? I have a 255 lph pump that needs to be installed. Will this correct the problem or should I trash the MBC?
