bs eliminator help
306dsm2.0
43
Feb 26, 2003
Cary, Illinois
I just purchased my balance shaft eliminator kit from ffwd connection and I was wondering what other parts do I need to buy such as gaskets and what not to make sure that this is only a weekend project because i need my car for transportation. I would appreciate it if you could help. By theway I have a 1995 eclipse gsx.
You will need to get the turbo drain tube gasket, Oilpump cover gasket, filter bracket gasket all on top of the kit that you just bought.
You will have to use silicone sealant on many of the parts when putting everything back together to prevent leaks. Also get some locktight for threads, assembly lube/grease and oil (for the oil change).
Good luck
Austin
