dsmcurse
- 968
- 14
- Aug 14, 2009
Pasco,
Washington
So I'm entertaining the idea of using nitrous on my car. I'm gonnaa be hittin the dyno agin here in only a matter of days. I have this ZEX bottle just sittin here doin nothin so I figure I might as well throw that biatch on the car. (Hey it might be the differance from 570HP or 600HP) my intake mannifold is already set up on direct port water/meth injection (300cc squirter in each runner)
I'm planning to get a bung welded into my lower intercooler pipe or my initial endtank on the FMIC. I think that spraying a 50HP jetted nozzle befor the intercooler is gonna make the nitrous go through the guts of the intercooler and make that boosted air flowin through there even cooler. I can then imagine the boosted air being a lil spicy with NOS mixed into it. (Maybe that effects the nitrous/air ratio-mixture?) The boosted nitrous air will then go through my throttle body and into my intake manni that has direct port meth.
Now here's my quiestion. My blow off valve is 50mm tial knock off non re-circ open dump only kinda blow off valve. If nitrous is flowin through my IC pipes and at throttle let off and blow off valve releases air, there will be a bit of nitrous too huh? So if my BOV poofs out a lil nitrous....? Am I an idiot? Am I askin for trouble? Will it ignite? I have a turbo header that's hot as hell under there!
Will the air flow off me haulin ass down the free way be enough underhood air flow to make sure the BOV air (that will be spiced up a bit from NOS) rushes straight to the firewall area? Will the fans they place in front of the car at the dyno be enough air flow to push that stuff away from my turbo header?
I can imagine pre intercooler NOS set up workin good, my only fear is my blow off valve dumpin spicy air in my engine bay. Can I please get some feedback from some experienced nitrous user's? Wiseman? I'm reallly sincerley asking about my BOV dumpin with NOS that was in the pipe. Would I be better to bung the IC piping after my BOV? That sucks tho cause then the juice will be spraying super close to my TB. I wanted to sray at a very far away point on purpose, kind of a long-route nitrous path. Dig me? Any thoughts on doin this?
Thanks in advance.
Thanks in advance.
Like Ben said above... the "boom" stories you hear about Nitrous Oxide are tanks exploding due to excess pressure.
