98GST
- 80
- Jun 24, 2002
how do i reprime the oil pump??? use a pressure gun and pump oil through the hoel the oil feed goes to or through the thing the filter attaches to???
Not in my limited experence. Unless a lot more than just the turbo got swapped, it's not much different than an oil change as far as priming the pump.Originally posted by RipperXX
uhh this isn't a common problem when swaping turbos is it??
Originally posted by 98GST
how does one pressurize their crankcase? and how do you pull vacuum on your turbo??? and when you did all of this did you get oil out of the turbo or did you test it coming out of the feed or the filter? im just trying to pump oil through a new turbo if that clears up anything
ooooooooh....
Im stupid sorry. Now are you talking about the hose that goes to the intake? that some people put a breather filter on?
