JDM Engine Installation List onto a 2G
cait sith
2,037
15
Nov 22, 2002
Brooklyn, New York
This is totally against eveything that I've ever said about JSPEC this and that, and how I always said that I'd never buy a JDM motor because they're just too much of a risk...
Well, I spun a bearing a few weeks ago, and have had very poor luck trying to find a beater (I commute in my GSX), and I don't quite have the fundage to build up a bare sixbolt, and my tranny is starting to crap the bed. While getting rides is OH SO MUCH FUN, I'd rather be driving my own '97 GSX.
PLEASE DO NOT MAKE THIS INTO AN ARGUEMENT ABOUT HOW THE JDM ENGINE IS THE SAME AS A US SIX BOLT. I KNOW THIS ALREADY AND IT IS CURRENTLY UNAVAILIBLE TO ME FOR PURCHASE.
Currently the list of things that I'd swap out off the 2G motor comes to this:
  • 2G Exhaust manifold (would be ported upon removal)
  • Water pump (I had a new one installed last year. Might as well)
  • My AGP "big T28" with ported O2 housing installation ** (See note at the bottom)
  • 2G Throttle body port matched to the JDM Intake manifold. (For ease of use, I'm just going to stick with the cyclone and but not make use of the hoses and all that crap. At some point I may put on a sheet metal intake just for shits and giggles)
  • Coil pack (I heard these like to get damaged)
  • My ACT2600 with fresh disc on a machined for the ACT Spec sixbolt flywheel.
  • Stock Accordion 2G Turbo intake and MAS would be retained.
  • Any other recommendations would be appreciated! Should I change over my newer Clutch slave cylinder to the new tranny? I'm kind of lost as to what to do about electronics to put on the newer motor.
** Note: I'm curious on this point because typically the Garret blend turbo's aren't installed on 1st gens. Is it the oil lines/water lines? If so, I can always Aeroquip those. Or is it the IC Piping (I'll be retaining my stock 2G IC and piping). Input on this would be appreciated.
Things that I would be doing while the engine is out of the car:
  • New Timing belt and accessory belts. Maybe get one of those Power brand "super strong belts", or maybe not.
  • Removal of balance shafts. Don't need those throwing up on me.
  • All fluids will be drained and replaced with their proper fluids
  • Removal of AC, lines, belt.
  • Removal of cruise control.
  • Anything else?
After all installed and whatnot, and hopefully running, I'd do a full synthetic install and then drain, rechanging the oil and plugs after doing a MCCC treatment.
And finally some misc. crap that I've read/thought of..
GVR4 motors are setup for an external oil cooler. I'd like to know if anyone's kept this option and have installed an external oil cooler with a VR4 motor on something other than a '90. Cooler oil is ALWAYS good.
Other than doing those things, that's about it. I don't want to start digging around pulling the headgasket, or changing to '95 pistons. I need to DRIVE the car.
On a final note: I've been having trouble deciding on which vendor to get a GVR4 motor and Tranny. I need a GOOD MOTOR and tranny that will hook up to a DSM rear end, from someone who can provide compression checks, mileage (not as important, but would be nice), and status (like they can look under the valve cover and tell me how it looks under there). I really don't want to just end up with something that I've already got.
Thanks guys.
I have a 92 vr4 engine in my 97 gsx
I had to chang the power steeing pump and bracket
-alternator
-2g driverside motor mount with 1g tensioner
-2g starte and mounting plate
-intake manifold
-o2 sensor
-and some plugs I had to change to hook up some sensors on the thermostat assembly on the head, cuz they where different.
I kept the oil cooler option, used a after market cooler though. the only problem I had was the thermostat assembly dont have a coolant cap as on the 2g, and there also was no place to hook up the over flow line anywhere, so there is a problem with filling the coolant, because you cant take it off of the 2g head, it wont fit
Hope I helped out a lil bit, maybe some one can help me out with the coolant thing, too!!!!
Cool, thanks for the information!
Anyone else?
i just blew out my motor on my 98 gsx about 2 weeks ago and am going through the same things isn't so much fun getting a ride to work in your girls car.
I talked to AL at A1 imports and he is having just about the entire front clip of a 91 or 92 GVR4 come in on 4/1, it's the RS w/510 injectors and the B16G, let me know if you want his number, i believe he's in NC.
When i talked to him he was willing to get any and all information i wanted, (very nice guy) unfortunitly i have decided against a 6 bolt swap, and will be going w/a jasper rebuilt because i cant wait 5-6 weeks for a slowboy rebuit.
Check your PM's.
You want the 1g intake manifold and throttle body. You might need one from a 92 plus to make use of your throttle postions sensor.
Use everything from your exhuast and turb, o2 housing ect because the 2g stuff is bigger and better.
Use everything 1g for the intake throttle body and so on.
Use a 1g fpr and 1g rail because it has more options for fpr mounting in the future.
Use a balance shaft eleminator kit form turbotrix.com, you will need new front cover and oil filter housing gaskets.
Also replace the throttle boy, intake manifold, exhuast manifold, turbo and downpipe gaskets while you have everything taken apart.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
