o2 housing install
95DSMTurbo
50
Feb 17, 2003
Dayton, Ohio
i recently purchased a tubular o2 sensor housing and i am having a little troble getting the stock housing off. it seems there is not enough room to fit any type of socket in there to get the 2 lower turbo bolts off. in fact, the only thing that can fit in there is an open-end wrench, which does not give nearly enough torque to get those old, rusty bolts off. i soaked the bolts with penetrating oil a couple days ago, but to no avail. the only other thing i can think of is removing the radiator fan. does anyone know if this will give me enough room to slide a breaker bar over the wrench?
Did you take the turbo off? Thats really the easiest way to do it. Make sure you dont pull off the stud in the turbo.
