mike gigante
- Apr 5, 2002
I posted a while ago, I have the stock O2 Censor Housing. I am running around 16-18psi on stock turbo, and when I am getting up near full boost all of a sudden the car jolts, ill chirp tires and it feals cool. The problem is it will keep doing this over and over through out a whole gear and then the same thing in 4th, 5th as well.
All gears except for first because it is such a short gear. I have a air/fuel ratio guage and I am always ina good zone. I have a 120 external fuel pump and pushing about 65LPH I believe it is. (I have a fuel pressure regulator) If I pump any more then that I start drowning. The car is running great except for that. any one here in south florida? Fort Lauderdale area? maybe we can hang out and some one can check it out. If you have any ideas let me know. also I am curious about a oil leak on the hose going to the top of the turbo.
Let me know.
Let me know.
and that is what I thought originally, but a while back my friend posted here and some one said maybe o2 sensor... but what could be the fuel cut? I guess I should lower my boost all the way and see if it does it and go from there...
