Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Bolt-on Tech
Bolt-on Tech Intake, exhaust, intake manifold, ignition, fuel system, cooling, etc - specific to 4G63 turbocharged DSMs.
Reply
LinkBack Thread Tools
Old 03-26-2003, 12:04 AM   #1 (permalink)
Proven Member
Classifieds Rating: (2)
Reputation: larryd is an unknown
[RESOLVED] Thread and Sizing of Oil Port? (BSP) [Merged 1-8]
There is a bolt on the front of the head that can be used as an oil source, I need to know what size fitting and thread I would use for this. Im getting my oil supply off the side of the head right now but I want to hook up an oil pressure gauge in the engine bay off the front of the head to verify oil pressure at that point. Can anyone tell me the size/thread?
Offline
Related Auctions
Sponsored Links
Old 03-26-2003, 12:31 AM   #2 (permalink)
Vendor
Classifieds Rating: (0)
Reputation: Z1500 is an unknown
It's 1/8 british pipe thread.
Wait, I'm second guessing myself now. It may be a metric like M10x1 or something.
Offline
Old 03-26-2003, 12:34 AM   #3 (permalink)
Proven Member
What is british pipe thread? Well I ordered an autometer mechanical oil pressure gauge and it says it comes with
"Includes 1/8" and 1/4" NPT fittings along with 6 ft. nylon tubing."
I guess Ill see if it fits when I get it here
Offline
Old 03-26-2003, 01:00 AM   #4 (permalink)
Proven Member
Reputation: DrZiplok is an unknown
1/8th NPT is very close to the M10x1.0 that's used in a variety of places around the DSM. However, from memory the port (I think it's actually just a plug related to the boring process, but threaded in) looks to be more like M6 or M8. At any rate, it's going to be metric; you'll probably want to drill and tap the hole or hunt down a suitable banjo setup.
Offline
Old 03-26-2003, 01:13 AM   #5 (permalink)
Moderator
Defiant's Avatar
Classifieds Rating: (1)
Quote:
Ah, the modern age of automeering... no more BPT, no more Whitworth fasteners, lots less metallurgy that once threaded in, effing welds itself together forever. American fine, 1/4-28, British 1/4-26. Yeh, that won't be much trouble....
Naturally, out there on their own little island, the damned limeys had to come up with their own way of measuring... so we'll line up three barleycorns, and that'll be an inch.
Which is still ahead of the &$^% French, who figure they know so damned much they'll just use the _planet_ as a gauge.... argh.
For the current problem, can't you just yank the bolt and check it?
Offline
Old 03-26-2003, 01:14 AM   #6 (permalink)
Proven Member
How exactly do I check thread? I guess I could take the bolt to the local hardware store and see if I can find something to thread onto it.
Offline
Old 10-25-2006, 08:48 PM   #7 (permalink)
Proven Member
Region: Tri State
Reputation: 1stGenRocks is pretty helpful and trustworthy1stGenRocks is pretty helpful and trustworthy
what size threads?
Quick question but I couldnt figure out what to search to find it.
Does anybody know what size/pitch the holes for sensors in the thermostat housing are? I want to get some of those nice allen head plugs to fill in the extra holes from having a 6bolt housing on my 2g. I'm also thinking I can pull the tube and drill and tap the hole for the turbo coolant feed since I dont have any waterlines hooked up.
____________________________
Rob
Offline
Old 10-25-2006, 11:37 PM   #8 (permalink)
Proven Member
95blackGsTurbo's Avatar
Region: Southwest
Classifieds Rating: (-2)
Reputation: 95blackGsTurbo is an experienced, knowledgeable member worth listening to95blackGsTurbo is an experienced, knowledgeable member worth listening to95blackGsTurbo is an experienced, knowledgeable member worth listening to95blackGsTurbo is an experienced, knowledgeable member worth listening to
Depends which one's. Would need a picture to see which one's you are plugging.
Adam Thilges
Offline
Old 10-26-2006, 04:14 AM   #9 (permalink)
Moderator
Defiant's Avatar
I suspect they'll be British Standard Pipe, or a similar self-sealing tapered thread. Most Japanese sensors use that thread. Look to Earl's, Russel and the like for adapters.
Offline
Old 10-26-2006, 05:58 AM   #10 (permalink)
DSM Wiseman
95GSXracer's Avatar
Timeslip: 8.979 @ 156.140
Region: New England
Defiant is correct. They will be 1/8th, 3/8ths, etc pipe threads, but they will be BSP, not NPT. Determine the diameter the same way you would if you were looking for NPT parts. In fact NPT parts will usually go in a few threads, so if you have NPT stuff around it's easy to test fit. The different between NPT (27 threads/inch) and BSP (28 threads/inch) is one thread, IIRC. I find that www.mcmaster.com usually has a great selection of plugs and other parts in BSP sizes, and they are cheap.
Kevin Jewer
-2005 EVO RS
-1992 Talon RWD
Offline
Old 10-26-2006, 04:37 PM   #11 (permalink)
Proven Member
Region: Tri State
thanxs. I'm looking for one for the sensor in the upper half of a 6bolt housing btw
Rob
Offline
Old 11-29-2007, 04:53 PM   #12 (permalink)
New Member/Lurker
Region: Tri State
Reputation: AuctionDrctDSM is an unknown
searched and searched but cant find..1/8btp to3/8 ntp adaptor
I have searched and cant find anything, I hate starting new threads, but I just cant find this one!
I am looking for a 1/8 btp? to 3/8 ntp? adaptor. I am tring to hook up a oil pressure gauge and cannot find a fitting! Any help would be great!! thanks
Offline
Old 11-29-2007, 06:53 PM   #13 (permalink)
Proven Member
Region: SoCal
Classifieds Rating: (6)
Reputation: Spades is an unknown
try 1/8 bspt to 3/8 npt
Online
Old 11-29-2007, 06:54 PM   #14 (permalink)
Proven Member
D_Eclipse9916's Avatar
Region: Mid Atlantic
Classifieds Rating: (4)
Reputation: D_Eclipse9916 is pretty helpful and trustworthy
Autometer sells an adapter, try them.
Offline
Old 11-29-2007, 07:22 PM   #15 (permalink)
Proven Member
Region: Midwest
Reputation: gsx951 is pretty helpful and trustworthygsx951 is pretty helpful and trustworthy
You have your terms for describing the thread a bit messed up and this will kill your search.
B.S.P. = British Straight Pipe
N.P.T. = National Pipe Tapered
1/8 BSP is 28 threads per inch and .383" in major diameter. Very close to 1/8 NPT, which is 27 tpi and .405" in diameter.
For me, I found it easier just to chase the BSP thread with an NPT tap.
Auto Meter Metric Adapters: ATM-2269 - summitracing.com
Offline
Old 11-30-2007, 02:04 AM   #16 (permalink)
Moderator
Defiant's Avatar
British Standard Pipe.
British Tools & Fasteners - BSW Thread Profile
Offline
Old 11-30-2007, 08:39 AM   #17 (permalink)
Proven Member
turboglenn's Avatar
Region: Midwest
Reputation: turboglenn is extremely helpful and trustworthyturboglenn is extremely helpful and trustworthy
+1 If possible just tap it up to the next NPT size which in your case seems to be the thread you need to have anyway. I remember hating having to track down brittish standard bolts on some older brit bikes i've worked on.
Offline
Old 11-30-2007, 10:41 AM   #18 (permalink)
New Member/Lurker
Region: Tri State
I just forced it on! After the first thread cought it went on fairly easy. THANKS!
Offline
Old 11-30-2007, 11:23 AM   #19 (permalink)
Proven Member
it will possibly leak over time like that, never force anything in a bolt hole that it was not meant to be in. This is your fair warning.
Offline
Old 01-17-2008, 07:08 AM   #20 (permalink)
Proven Member
Reputation: kingjust is an unknown
Thread & Pitch
Whats up fellas?! I got a question to ask of you all. I just bought a forward racing oil filter bracket for the seven bolt. And here is the dilemma. On the old filther bracket, there are like 3 or 4 port used or bolted up. Like the oil pressure sending unit, or the oil pressure sensor switch. Another on unused, and the 3/8 one used for feeding the snail. Now I was assuming that the smaller port were 1/8 npt, but I took a brass fitting that is going to be used to mount the fuel pressure gauge on my aeromotive FPR, which is 1/8 npt, and tried to screw it in. It didn't fit... so I was like damn, what the hell is it. I'm assuming metric, but unsure, and I cannot find anywhere what the thread and pitch are for the sensor and sending unit. I'm trying to install a t or street brass fitting for the sensor and sending unit. Let me know if you guys know anything, thanks!
KJ
Offline
Old 01-18-2008, 03:27 AM   #21 (permalink)
Moderator
Defiant's Avatar
They're British pipe thread. Summit Racing has adapters. So will large performance shops.
Offline
Old 01-18-2008, 06:02 AM   #22 (permalink)
Proven Member
Quote:
Originally Posted by Defiant View Post
