mopar4Life
- 98
- Mar 6, 2003
I got one of those sunpro air fuel meter gauges and it has 4 wires on it
-Green to be connected to the oxygen sensor check connector under the
passengers kick panel witch iconnected with out problem
-Black which connect to the engine ground no prob under the driver kick
-White which says to connect to head lights or tail lights before the head
lamp swtich which i conncted to a fused pos from fuse box and has a switch
-Red which says to connect to ignition key wire after a fuse but i dont want the gauge to turn on when i start the car i want it tu turn on when i flip the pos swtich
dont know where to put the red tried pos and neg help
