just bought a tube header..
twenty5psi
815
Nov 7, 2002
Williamsport, Pennsylvania
and was wondering what i can do to prevent cracking?..i was thinking of getting it ceramic coated but maybe you guys have a few good ideas..the car is a daily driver too..any suggestions..thanx
chris
theres not too much you can do to prevent cracking...cracks usually form on tubular headers do to poor design, material used, or types of welds....you can try and brace the manifold to the block somehow to help it support the weight
yeah it has a full brace to support the turbo and downpipe so i guess thats a start..ive just heard alot of things about getting them ceramic coated..
as far as i know, the main use, if not the only use for ceramic coating, is to keep the the heat in the exhaust gas in the header from transferring into the engine bay. That and it increases exhaust effencieny and whatnot a little. I'm just kinda piecing this together from what i've read though.
Thin walled tubing used on most of the DSM headers tends to split at the seams and welds. In most cases the wire or filler rod is a different grade of metal than the actual tube. When it goes through the repeated heat cycles the weld and the tube expand at different rates causing the cracking.
When you ceramic coat the entire component it helps to keep the material temperature lower and stable so the expansion isn't as drastic and ultimately reducing your chances of cracking. It's still possible but not as common.
didn't read the thread to see if someone has already said this but you can insulate it.. that will keep it from cooling off so quick so it will be a somewhat controled expantion/contraction.. although it will heat up faster..
Ceramic coating will do wonders for the manifold to make it last longer. We ceramic coat even cast manifolds to help them last. That manifold with either last or not depending on what it's made from. If it's thinwall 304 then it's gonna crack very quickly espically if they weld with 304 rod with is usually the case. It needs to be fairly thick, and welded with 316 minimum for it to even last 1 year.
LOL you guys are funny sometimes.
Thermal wrapping ***GREATLY*** shortens the lifespan of headers and manifolds. It will turn your tubular header into dust quicker than you can believe.
The best thing you can do for longevity is brace it well.
yeah ive heard horror stories about wrapping the mani too..i will be going with a ceramic coating..does anyone know if i get the mani ceramic coated with a few layers instead of one if itll last longer?..thanx
chris
chris
Ceramics are very thin coatings, typically applied at .0003" to .0015" thickness. If you get it on thick it will not last at all, expect failure within 2-3 months or sooner. If it's prepped correctly and applied correctly it should last 10 years on a daily driven vehicle.
Bracing is actually one of the biggest things that crack the headers. You need a thick walled tubing and it should be in T321 stainless. Noone is using T321 though. T304 low carbon works pretty well too, but is at its upper limit of heat. Don't wrap them, that will create more problems than good. The header should be stress relieved several times during the manufacturing, but I don't know of anyone doing this.
well i havnt decided on a turbo yet and what i meant by the l2r is that id like to get a t3/t4 turbo along the lines of the l2r..sorry for the confusion..thanx for all the suggestions everyone..
Oh ok, just didn't want to see someone buying parts that will be un-necessary.
AGP offers a garrett version of the L2r that will bolt right up to the manifold btw.
thanx..i didnt know agp did that but ill check it out when i go to buy one..but before that i need a HG..LOL..22 lbs of boost on my stock sidemount and racing on the highway blew mine..:cry:
i thought i said that :confused:
oh well jay hass restating something i said has to mean im at least on the right track :cool:
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
