SAFC-II Rpm calibration?
Phoenyx
222
Nov 18, 2002
Orange County, California
All:
My SAFC-II reads lower rpm than my analog gauge. How do I calibrate this?
Thanks,
-M
your cars stock tachometer will always read higher than the S-AFC. Why? because the stock one is incorrect =) you cant really fix it either.....BTW, were you the dude that i met at the March meet (fremont central park) who i showed my S-AFC to?
Yea, that was me..
Thanks for the info.
-M
why is that sometimes the TPS sensor says 0.0% when your on the pedal little. and when you go to full throttle it seems to recalibrate itself and all is fine until you turn off the car and start it again.
Its really 10% on the TPS sensor at idle. I read that somewhere because i also questioned the S-AFC monitoring 0% while my pocketlogger would show 10%.
