Maxium Boost on 1991 TSI
Bd1000Eclipse
Banned Member
756
Nov 3, 2002
i'm picking up a 1991 tsi today which is in great shape. it has a mbc, hacked airbox, k and filter, exhaust, and gutted cat, what is the max bosot i can run on this car? how much if i rewire the fuel pump? thanks
ps, i searched and found nothing.
Depends on the condition of the motor too.... I ran 14PSI clean and easy, then upgraded the fuel pump and rewired, Now i can run 17PSI with no problems. Every car is slightly different though depending on miles and running cond. just make sure everything is in good shape before you push it too hard. And yes Hi octane gas is required at this point:thumb:
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
