oil flange/return line differences???
Cody Morris
97
Jun 5, 2002
Is there a difference in the 14b (1G) and T25 (2G) stock oil return/flange lines that go from the oil pan to the turbo? I've been told the line I have does not lines up, its to small, the end needs to be wider for the two bolts to line up correctly. So I figured maybe I got the wrong line? Anyone?
Yes there are differences. There are early 1G, late 1G and all 2G lines... Either one you shoudl still be able to use (1G) even a 2G and just drill out the holes a little bit.
You can either modify your line to fit the new turbo. I used a dremel on 2 of them (helping friends) and have never had a problem.
Your other option is to get a 1g oil return line, which will bolt up to your oil pan.
my (early) 1g wasn't long enough so I drilled out the top holes on the 2g line and it fits perfectly.
