90 EagleClaw
- 35
- Oct 20, 2002
I dont really get why my car is so slow. I have alot of work done and it seemed to be tuned ok but not perfect the day I raced it. I went 13.37@103mph, with a T3/T4 50 trim, FMIC, 650's, AFC, etc etc at about 22psi on 112 octane. Didnt have the logger with me. Now my car weighs 3300 with me in it, thats roughly 280HP to the wheels. I feel like I should have alot more then that. Could just minor tuning adjustments net a 50 or more HP gain? Cause otherwise I dont know what the problem is. After I raced I went home and checked things over and found my base timing to be slightly advanced at 8 BTDC, adjusted it back to 5. Went out and retuned it checking knock, egt's and whatever. Gtech'd it (i know) and went 0-60 in 4.73 at 18psi on pump gas. Didnt run a 1/4 yet. But even still, 4.73 0-60 seems like a low 13 1/4. So what the hell is the deal?? My best time with a stock 14b, IC and injectors was 13.66 at 99.8. I think I should have gained alot more then 3 tenths with my new setup. I'm going to try to race it again this sunday and will give an update, but before then could anyone give me some tips on what might be making my car run slow? Oh and I have no boost leaks that I know of, checked for it before I went racing, and my compression is 155 across. Thanks for any info.
If you undestand A/R you understand that it's not measuring the entire housing.
