Newlogics
- 1,106
- 18
- Jul 23, 2002
San Leandro,
California
Something unusual is happening to my 1G lately.
First and formost, my timing belt tensioner is failing (makes squeaking noise). *About* the time it started failing, the car started to loose loads of power throughout whole lower rpm range.
IF I slowly bring it up to about 3500rpm and the gun it, it's *usually* launches very nice, but got forbid I give it some throttle when i'm below 3K. (All this assuming I'm already in gear and rolling)
Car just doesn't pull at all. Turbo builds boost earlier then usual, EGTs fly high (I'm talking past 1600F unless I let off) and I get NO pull whatsoever. That little acceleration that I do get feels jerky a bit, but doesn't backfire.
All this I'm describing does not involve full throttle. It does that at virtually any attemt to accelerate.
I tried adjusting fuel delivery with SAFC, but it seems to have little of no effect at all. Since it's not doing 100% of time, It's hard for me to even pinpoint specific rpm range that has mixture problems (if that indeed is the problem)
Here's the summary:
If I give it throttle when I'm below 3000K, I don't get any pull, my EGTs rise and boost biulds up quicker then normal.
When it gets to about 4500, there is a 50% chance I get all my power back all of a sudden. Otherwise I'm still crawling untill my EGTs are so high that I have to let off.
Could this be detonation ? -- Why at partial throttle ?
Oh yeah, i'm also showing knock of up to 43 when it happens.
Help Help Help.
P.S. My timing belt is geting fixed tomorrow
Here's the summary:
Help Help Help.
