SAFC install on a 1G
99GST
245
Dec 26, 2001
Nashville, Tennessee
I am looking for an installation "how-to" or document which tells me how to put an SAFC into a 1G.
There was a link to it on the VFAQ from Jon at gvr4.com, but the link no longer exists.
Can someone please help me here?
Thanks,
Nathan
Ok first goto google and put the url of the missing page in the search 2. go ahead and click the CACHE page you will get the directions but you will not get anypictures to go with it. 3.http://www.plymouthlaser.com/safc.htm go here for another source with pictures then 4. goto rre's website and look for the a/f meter gauge installation Why you ask because it will give you a very very good reference on how to view the pin outs on the ecu connectors. It will only show you a few of the connections but use the ones they show to reference all the others. The view is looking at the connectors as if the wires were coming at you NOT as you were looking at the face of the connectors.
Here is an excellent source from RRE's web site to get you started setting you up after install http://www.roadraceengineering.com/newafc-print.htm
here is the rre reference to the pinouts http://www.roadraceengineering.com/instructions/afmeterinstallinstructions.htm
also get the pinout sheet for the ecu on www.dsm.org using all of the references will assure you a quality installation. If you install it right :)
Excellent!
I think this is what I need.
Thanks alot for taking the time here.
Later,
Nathan
