DeathBeast
- 177
- Mar 29, 2002
Bay Area,
California
Problem with car:
-Broken clutch
-Leaky Transfer Case
While the car is apart I'm planning to get the rest of my mods done before I put it back on the road again.
Here are my plans to get the Talon running again. If there is anything I should do while the car is taken apart, or any parts that would be better or less expensive, let me know:
1.)ACT 2600lb Clutch / Fidanza Flywheel
2.)Transfer Case
3.)Toyota Supra SMIC
4.)RnR 3" O2 Eliminating downpipe
5.)Charged Air Fuel Pressure Regulator
6.)Palm Piolet / Dattalogger
7.)Big 16G Turbo (if there is enough money)
Thanx,
DeathBeast
-Broken clutch
2.)Transfer Case
Thanx,
DeathBeast
Id just skip the fidanza thing, IMO, the money is better off spent elsewhere. For 400$ you can get quite a bit. Id like to help but your profile says your pretty much stock. If so then id start with intake, mbc, fuel pump and a boost gauge. This woudl bring you up to about 350$ for all that. Then after that decide on what type of fmic you will get in the future (cause we know you will) and buy your intercooler piping accordingly so you don't waste money.
