DinK
- Feb 12, 2003
I was just playing with some numbers at work today, and I want to see if you guys think they fit. I was wondering how well crank hp output could be determined by air intake, or more specifically boost pressure.
Totally stock the engines run what, like 8 psi? Add that 8psi to the 14psi of normal atmospheric pressure to get 22psi overall. Multiply that by around 10, and you get 220hp. Sounds about right for a stock engine with some standard breathing mods.
Then, say you go "stage 1" and stay mostly stock on stuff like injectors. 15psi seems to be the recommended level without heavier fuel delivery. Add that 15 to the 14 and you get 29psi, times 10 again is 290hp. That's right around the 300 that this site's "stage 1" mods claim.
Doing the same math in reverse, to get 400hp you'd need 26psi of boost, for 40 = 26 + 14.
So, in your experience, does this seem at all accurate? I realize the boost numbers are usually peaks and it often goes down by the time you hit the end of the tach, but it still kinda makes sense that there's a linear air-hp relationship. After all, horsepower is energy per unit of time.
I'm not too sure about the 26psi = 400hp in particular. I don't have that much knowledge about these cars. Would be cool though, if 1 psi was roughly 10 horsepower, it would make power guesstimates rather easy. =)
