90AWDTalon
- 877
- 3
- Jan 5, 2003
Everett,
Washington
Yesterday I found out I need a new turbo and exhaust manifold. My original plan was to do all the supporting mods and then save up and get an AGP L1R. Thats not going to happen now. I'm basically trying to decide between small 16G and Big16G. I was thinking Big16G at first then I started looking at some compressor flow maps. I'm a beginner when it comes to flow maps so I don't know if my logic is working so I need some input from you guys.
My goals are to have a daily driver that can run mid to low 12's, and have as close to zero boost lag as I can get. I plan on doing more autocross than drag racing. I think the quarter mile goals are possible with either turbo. Looking at the flow maps the small 16G looks more efficent than the Big16G untill the boost gets turned up much higher than I ever plan on going. They both look like they produce similar flow at the boost I'll be running, but the small 16G is at higher efficency. Am I right in how I'm interpretating these maps? How much faster does the small 16G spool than the Big16G?
Any input anyone can give would be great.
I still plan on doing all the supporting mods, just after turbo upgrade now instead of before.
