Turbo Guru
- 609
- 2
- Jun 15, 2002
Tampa,
Florida
As some of you already know I have my head off and may do a rebuild. My question is about the pistons that are in my motor. I can only see the tops of the pistons and I am curious as to which they are. The reasons I am curious are:
1) The car already has ALL of the free mods done.
2) The car already has some upgrades done ie- ACT clutch, UICP, K&N, Short- throw shifter, aftermarket (dejon?) throttle body elbow.
3) The transmission has been rebuilt.
4) The motor has been apart (the person said it was rebuilt) and the timing belt, etc... has been changed.
5) The question at hand is maybe this guy already had 2G pistons or some others installed. I would call him and ask, but he is out of town for a month or so and I don't have that long...
The pistons have no writing or marks, flat tops (with no dish) and, have standard valve reliefs. The compression test I ran to find the head gasket leak showed 180, 176, 180, 120. The compression is pretty high for 7.8:1 1G pistons with no buildup on the piston or in the combustion chamber. I was under the impression that the compression results for a 1G should be in the 150's.
Does anyone have compairson (sp?) pictures of the tops of the 1G and and 2G pistons? I will try to take some pics of what I see and post them tommorow.
) after being over-sprayed with copper seal I discovered that they have a slight dish and "< 63D" on the face. With the carbon on the piston face it was not visible (no shadows). So what pistons are these? Remember the compression test read 180psi which is high.
Oh well, we'll see.
