Greddy FMIC
Mitchel63
270
Mar 27, 2002
Exactly what pipes are included in the Greddy FMIC kit? I heard a few different anwsers to this question already!
I have the small Greddy and it comes with all piping to and from the stock IC location. you will need the upper intercooler pipe (that has the BOV on it), but that is it. Even the stock one will connect if you wanted it to.
If you get the big greddy, you will need in addition the lower ic pipe (it will run from you turbo to the lower part of the IC). You can use the stock one but I would suggest a hard pipe. You will also need an upper intercooler pipe. Greddy will give you a bunch of silicone hoses to mate the pipes.
the best answer to your question has already been states.. the Greddy FMIC comes with the pipes to connect to the stock intercooler location.. you should replace the UICP and LICP as well
