Anyone having overheating problems with a front mount?
Mistaspakles
227
May 17, 2002
It finally got a little hot and muggy here in Minnesota so my GF made me turn on the AC. When I turn it up all the way, my stock temp gauge started rising. I then quickly shut the ac off, and it started to go back down. Is this common on a hot day with a FMIC? Anyone know a way to help it? I've got a bottle of Redline Watter Wetter in it. Any other suggestions?
I had the same problem in Eagan while running with a WS6...... car temp went up...... for about an hour until I parked at Midway to watch the cars.....
Scared me as I just finished replacing the hose's, thermostat... thought maybe my overflow tank was empty again which is what cause my last over heat.
-brian
Well as long as you put the Redline Water Wetter stuff in to prevent corroding you can run less coolent and more water, try putting in 25% coolent (orange), 75% water, and of course the bottle of Redline. Other stuff to help out but more expensive would be to buy the FAL slim fan kit and/or the Fluidine radiator.
Mario
I have no problem in over 100 degrees with FMIC. But I don't have AC or an AC fan.
Later,
