BoostinAWD
Supporting Member
- 818
- 17
- Feb 14, 2002
Layton,
Utah
Ok I currently have my head, flywheel, 1g big rods, and 2g pistons sitting in the machine shop.
They tore the head apart to inspect everything. The head is not warped and only needs a new set of exhaust valve guides, and valve seals.
They quoted me $650 total for all work to be done. Which is:
Resurface the head
Valve Job
New Exhaust valve guides
Upper gasket set
Machine the rods to fit the pistons
Press the rods on to the pistons
Resurface my flywheel to a .610 step height
Retap 2 of my broken exhaust studs
Cleaning of the head
Fitting the valves and pressure testing to make sure they seal properly
And reassembly.
Well heres the deal I went ahead and purchased a set of used valves on ebay, because mine looked like ####. They are stock valves that have been cleaned, resurfaced, and cut. Not sure what that meant but they looked good so I figured what the heck and bought them.
here are some pics:
I haven't actually received these yet, they are being shipped. But will these be good to use?
I am NOT going to use the stock cams. I want a set of HKS 272's but they seem to be non existent anymore. And they only places that seem to have them want $600. I want to maybe eventually bump my rev higher.
Should I get a set of crower springs and retainers or are my stockers fine? This is basically what got me thinking well if I get hks 272s why not get an upgraded valve train, and get some oversized valves while I'm at it. But I am sick of tired of waiting, waiting, and waiting. My car hasnt ran since august. I am not made of money. And the bill to be from my machine shop it a huge chunk of change for me. My next turbo is going to an L2R no doubt. But it's gonna have to wait. I still need to finish my fmic, get an act2600, prothane motor mounts, remove the balance shafts, etc, etc. DAMN this car
I've spent the past 3 hours going through dsmtalk and dsmtuners. And all the post seem to lead me nowhere.
Somebody give me some insight please.
I'm all ears tell me what to do...
Resurface the head
Valve Job
Upper gasket set
And reassembly.
here are some pics:
If anyones interested in them shoot me a pm.
Cams shoudl be fine until you really feel you need them. Just get yo shite together so I can see this bad boy....
