DSMNightmare
- 923
- 1
- Oct 23, 2002
Belleville,
Illinois
Hey, I just had to have this motor mount custom made for my car because with the Hahn Super 16G turbo the compressor out lines right up with the motor mount causing a really bad fit for the lower IC pipe. I don't know if all low IC piping has this problem but I had it with my Apexi front mount piping. The reducer would rub against the motor mount until it punctures through. NOT GOOD. So I called up my buddies at Speed Design in Godfrey IL and they set me up with a custom motor mount. As you can see it allows for a lot more clearance. If you have this clearance issue with your motor mount and rotating the compressor housing is not an option I suggest you call these guys. They do a lot of DSM work and they do it well. I suggest you check out thier site at:
http://www.rothbuilt.com/SpeedDesign/
