Login
Go Back   DSMtuners > DSM Forums > DSM Tech > Bolt-on Tech
Bolt-on Tech 4G63 intake, exhaust, intake manifold, ignition, fuel system, cooling, etc.
Reply
LinkBack Thread Tools
Old 10-13-2009, 08:49 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
Tech Posts: 827
Classifieds Rating: 4
Reputation: 91-gsx is pretty helpful and trustworthy
93' RX-7 Wheels without spacers
I was wondering if anybody knew how to fit the 93' RX-7 wheels on a 1G without using spacers. I do not trust spacers... I know many use spacers, but I was looking for something like a new but thicker hub assembly that will push the wheels out 15mm in the back and 10mm in the front I believe it is. If anybody has any information on this subject, I would really appreciate your help.
Advertisement
To browse the forums without the advertisements above, Login/Register
Old 10-13-2009, 09:41 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
knochgoon24's Avatar
Timeslip: 14.787 @ 98.290
Tech Posts: 1,992
Photos: 14
Classifieds Rating: 5
Reputation: knochgoon24 is pretty helpful and trustworthyknochgoon24 is pretty helpful and trustworthy
Quote:
The spacers aren't what cause problems. Problems are caused by not running a long enough stud. If you swap out the stock studs for some longer ones (they make stronger than stock ones) you should have no problems.
____________________________
Wes - '97 Talon Tsi AWD
View photos of this member's car  View this member's Blog
Old 10-13-2009, 09:53 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
turboking15's Avatar
Tech Posts: 176
Classifieds Rating: 7
Reputation: turboking15 is an unknown
Also from what i have read, it is important to use hub centric spacers. Non hub centric spacers put more stress on the wheel studs and that is what causes them to snap.
Old 10-14-2009, 12:20 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
Tech Posts: 827
Thanks for the replies guys. I have been looking for these hub centric spacers and longer studs, but have not found pictures of any with the ads. Any links are greatly appreciated. Also, I have read many different spacer thickness numbers when it comes to not grinding anything and just bolting the wheels on with longer studs and spacers. Any help with the rear and front spacer thickness I should run would be great as well. Thanks again.
Old 10-14-2009, 03:50 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
Tech Posts: 827
I called RRE and they did not have any longer studs in stock. Does anybody know of another place to get some spacers and longer hub studs? Preferably hub centric spacers. Thanks for any additional information.
Old 10-14-2009, 04:16 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
black_gst's Avatar
Tech Posts: 282
Photos: 4
Classifieds Rating: 3
Reputation: black_gst is more helpful than not
Direct Tuning - ICHIBA V1 WHEEL SPACER KIT: 4X100 | 54.1 | 12X1.50 | STUD
google is your friend
Old 10-14-2009, 04:17 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
MichaelSuch's Avatar
Tech Posts: 325
Photos: 8
Classifieds Rating: 2
Reputation: MichaelSuch is pretty helpful and trustworthy
Here's the studs
You need to do some measuring and get the right hubcentric rings, this place has a ton of them.
Hope this helps.
Old 10-14-2009, 04:18 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
TSIMonsteR's Avatar
Tech Posts: 1,181
Photos: 2
Reputation: TSIMonsteR is pretty helpful and trustworthyTSIMonsteR is pretty helpful and trustworthy
For extended studs try Custom Extended Lug Studs#-#Mitsubishi 3000GT#/#Dodge Stealth Parts
For spacers try Wheel Spacers#-#Mitsubishi 3000GT#/#Dodge Stealth Parts
98 GSX A/T
Jake
Visit TSIMonsteR's homepage!  View photos of this member's car
Old 10-14-2009, 04:36 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Proven Member
Tech Posts: 827
Quote:
Originally Posted by black_gst View Post
Thank you.
Quote:
Originally Posted by MichaelSuch View Post
Here's the studs
Hope this helps.
Thank you.
Thank you.
Old 10-16-2009, 08:56 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Proven Member
Slippi84's Avatar
Tech Posts: 3,822
Photos: 10
Classifieds Rating: 8
Reputation: Slippi84 is pretty helpful and trustworthySlippi84 is pretty helpful and trustworthy
Yeah extremepsi has the arp studs but I don't know about the hubs. I plan on running the FD wheels on my 1g too. Best rim for the buck when talking about weight and strength and looks in my opinion.
Sean aka Slippi
Old 10-20-2009, 05:52 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Proven Member
Tech Posts: 827
Quote:
Those seem to be the safest ones to go with. Thanks for the help Sean.
Old 11-05-2009, 05:47 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #12 (permalink)
Proven Member
Slippi84's Avatar
Tech Posts: 3,822
Photos: 10
Actually I don't know if you trust Weapon R but they sell some too for only 18 a set(4) so that would put you at 72 which is a good amount cheaper than the ARPs. But ARP is the juggernaut when it comes to fasteners.
http://www.andysautosport.com/eagle/...p00211850.html
Sean aka Slippi
Old 11-05-2009, 09:17 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #13 (permalink)
Proven Member
KiNg MaRtY's Avatar
Tech Posts: 108
Photos: 5
Classifieds Rating: 1
Reputation: KiNg MaRtY is an unknown
H&R also makes a really nice kit.
90 GSX HKS' Former Promo Car /92 GVR4 / 05 STi
Old 11-05-2009, 09:54 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #14 (permalink)
Proven Member
spooling 1g's Avatar
Tech Posts: 81
Photos: 10
Classifieds Rating: 0
Reputation: spooling 1g is more helpful than not
I didnt need spacers in the front for my fd wheels.
Old 11-05-2009, 10:14 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #15 (permalink)
Proven Member
1gDSM4g63's Avatar
Tech Posts: 1,249
Photos: 17
Reputation: 1gDSM4g63 is more helpful than not
If many mm do you need for the rear on a 1g and do you need to do a little control arm grinding?
Old 11-05-2009, 10:58 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #16 (permalink)
Proven Member
desolateboosted's Avatar
Tech Posts: 165
Reputation: desolateboosted is more helpful than not
No spacers in front if using tires 225 and smaller.
However, spacers and grinding required in rear if you have awd. FWD doesn't need any rear grinding because the suspension is differernt. There isn't a huge metal member/control arm piece running across. I think I used a 5mm spacer for each side in the rear.
Don't forget longer studs for saftey.
Some info
I ran the FD wheels on the original studs with no issues for a year. During that time I had numerous 1.8 60 fts and hard antilag 15psi street launches with no stud breakage. This was also without any hubcentric spacers, just the cheap put on, non centered type. This isn't to say it will work fine with no breakage on the studs, but thought I'd just share my experience.
Last edited by desolateboosted; 11-05-2009 at 11:07 PM. Reason: Auto-merged with previous post to prevent "bumping"
Old 11-12-2009, 10:53 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #17 (permalink)
Proven Member
ajinvista's Avatar
Tech Posts: 79
Photos: 19
Reputation: ajinvista is an unknown
Some info
I did AutoX with these also. No problems yet.
Reply
Bookmarks
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
RX-7 wheels with Spacers and Big Race Tires: Will it work? Nonrml4 Handling Tech 1 12-19-2006 04:14 PM
93 RX-7 wheels-Which Spacers? TurboB5 Handling Tech 4 06-21-2006 10:26 AM
please help! just put on rx-7 wheels w/spacers and rubbing ryu Handling Tech 5 08-15-2005 08:28 AM
3rd Gen Rx-7 Rims Spacers Needed dnhieu Handling Tech 6 07-02-2005 11:53 PM
Are 5/16 inch thickness spacers big enough to put 3G RX-7 wheels on? black97GSX Handling Tech 1 10-31-2003 10:06 AM
» 2010 DSM Calendars
» DSM Mechanics Gloves
» Recent Blog Entries
Update 4
by: Kevin TSI
Engine shots
by: Spdfreak
Best DEAL ever *Update*
by: 4Motion4g63
2.4 Liter G4CS build thread
by: Atuca
Possibly buying a new 1G
by: booostedGSX
» Recent Tech Threads
Title, Username, & Date
2.5 stroker
by: Hittman92
new head.
by: dadstsi
drive train problems... i need a pro!
by: black_gst
Skipped tooth
by: awzer2
Can I just replace the clutch disc?
by: ziggo0
» Latest Gallery Photo
User 1kwik4g
» Advertisement
» Current Poll
What will you be buying soon?
DSM Calendar - 38.10%
8 Votes
16 Votes
6 Votes
Total Votes: 21
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
