Need help on removing 2G ECU
Mistaspakles
227
May 17, 2002
Ok, for some reason I can not get the passenger side, side panal out. The driverside pulled out ok, but when I took out the one screw and tried pulling on it, it cracked right where that other "holder" is. The "holder/screw" that I'm talking about looks like a 1inch push pin. I can not pull it out for the life of me. Is there something I'm missing? Does the passenger side panel need to come out to get to that screw holding in the ECU?
2 push pins and a screw, one push pin is next to the seat back by the cup holder or actually under the cup holder. The panel is a pita to get out though because its tucked in behind the glove box, you have to clear the glove box first and then pull out on it.
No, you dont have to remove the glovebox. Its really straight forward to pull off...just a few screws which are clearly visable like Larry said.
whenI saw clear it I mean you have to pull the plastic part towards the back of the car first.. there is a lip on the end of that tucks in between the center console and the glove box..
