How efficient is APG L2R with 34mm int. gate?
WhyteSpyder
60
Jan 7, 2003
Ok guys I've decided to run AGP L2R and not FP Green now after looking closely with it so what I want to know now then is how efficient is AGP L2R with the 34mm internal wastegate? or will I need to run an external gate. I'm tight with $$$ now so trying to same $.
I have the internal gate and the turbo is very efficieant and I have no boost creep at 20psi.
Miss typo on my post there...meant to "save some $) anyway, thanks L2RTSiAWD. Did you get your L2R from AGP or where else? Where's the cheapest place I can get if from?
Direct from AGP is the best. I had one of the guys deliver it to my front door. Talk about awesome service.:cool:
AGP is the ONLY place to get an l2r.
Internal gate has gone 11.4s I believe on an l2r. Is that good enough for you?
Wth the internal gate and no fiddling I get a range of like 16-24 with my profec b. No creep, no spike.
Perfect for street/pump gas use. Kind of a pain in the ass if you want to run high boost at the track.
My internal gate works great. I started with it at like 13psi, and it held to redline, but that was with the actuater arm loose, and a cat still on. I now run 20psi on the street, and it never creeps. Running any lower is pointless. It has also been able to hold a constant 26psi with no problem. Im sure it will hold 30psi with ease.
