Silencer Removal
ChrisTopher19
Feb 1, 2003
OK, I read this in the DSM Go Fast Recipe Page.
"Remove the air horn in the air box and remove the silencer behind the MAF. All that the silencer is doing is quieting down the airflow when you romp on the loud pedal and your car starts sucking in more air. It does this though by putting a restriction in your intake system to make it quieter. If your worried about noise though you probably shouldn't be reading this.)"
How do I do this? Where's the air horn?
Originally posted by FINETUNED
While you are in there you should remove the lower honeycomb......Make sure you dont hurt the upper one your car wont idle right....
Where are the two honeycombs-- I found the one right in front of the snorkel.
