$459 for 4g63 rebuild kit worth it?
benleyd19tx
85
Aug 15, 2002
I found one here:
http://www.greenbaypartsworld.com/cgi-bin/webstore.cgi?page=4g63
and one here for $629 that's about the same as above with premium rings and also timing kit and oil pump:
http://diabloenterprises.com/Engine/TopLine/
I't to get that tax return, and it will be about $1000 or so. I want to do a rebuild for this price and to get it installed. So about $600 for parts and about $400 to have them installed. Or should I just by a JDM one for $1499?
I want to maybe in the future with the safe-ty keeping of an water\alcohol injection, see 350-400 on stock, rebuilt internals. I don't want to do a rebuild on the turbo because I will by a new one and sell the old one.
The OEM parts are still good parts if you can mix and match stuff to get a good combo. I orederd a long block and got a 7Bolt bottom with a 1G head and 1G cams. I wasn't complaing since the 1G Head flows better. But its your choice. I would call the place up and see what exactly that it is they are selling. If they are only using OEM parts, ask if they can send you mixed stuff.
Well, I really probably won't ever crack more than 250-300 h.p. I plan to sell it a little into the summer. But it's got a brand new rebuild on the tranny, so I figured why not rebuild the engine too and sell as generally rebuilt. Don't want to spend too much money. What all is required if I get an overbore? Do I just need the larger diameter pistons and rings?
